AutoCAD Plant 3D General DIscussion
Active Member
Mohamed_Yamani
Message 1 of 12 (811 Views)
Error creating project on windows 7
811 Views, 11 Replies
02-03-2010 11:54 PM
Hi. I am trying to start a new project inside Plant 3D. I got unhandled error.
I tried to open "sample project" I got error "The file you are trying to open is not a valid project".
Have anyone faced this probelm before?
*Jorge Lopez
Message 2 of 12 (811 Views)
Re: Error creating project on windows 7
02-04-2010 08:10 AM in reply to: Mohamed_Yamani
Hi Mohamed,
I've not encountered this issue and I am also using Windows 7. During
installation, did any error messages display? Are you running AutoCAD Plant
3D 2010 as an Administrator?
Jorge Lopez
"Mohamed_Yamani" wrote in message news:6330116@discussion.autodesk.com...
error.
Active Member
Mohamed_Yamani
Message 3 of 12 (811 Views)
02-05-2010 12:44 AM in reply to: Mohamed_Yamani
Not at all. The installation went well.
I tried to run the program in compatability mode and with all admin rights.
I think the problem happens because I am installing Plant 3D with C3D and MEP at the same machine because the error is related to getting Acad Object.
Have you any suggestion?
New Member
sahas
Message 4 of 12 (811 Views)
02-08-2010 03:05 PM in reply to: Mohamed_Yamani
Hi Mohamed,
We have tried to reproduce the reported issue using Windows 7. We have installed C3D 2010, MEP 2010 side-by-side with Plant 3D 2010 and followed the steps as per your message. But we were unable to reproduce the problem.
Please allow me to ask you two questions:
1. What was the installation sequence of all 3 products? Like I installed C3D first, then MEP and finally Plant 3D.
2. When you were trying with Plant 3D, was C3D and/or MEP also open in the same machine?
Thanks in advance,
Subrata Saha
Active Contributor
PHammink8001
Message 5 of 12 (811 Views)
02-09-2010 02:58 AM in reply to: Mohamed_Yamani
I was being advised not to run P3D 2010 under Windows 7. But to wait for release 2 of P3D. It could create some errors in your project.
Peter
Active Member
Mohamed_Yamani
Message 6 of 12 (811 Views)
02-09-2010 04:56 AM in reply to: Mohamed_Yamani
Thanks for your feedback. I check compatabile products with Windows 7 and didn't find Plant 3D.
I will try to use Vista or XP.
Active Contributor
PHammink8001
Message 7 of 12 (811 Views)
02-09-2010 06:15 AM in reply to: Mohamed_Yamani
No problem, I would use XP if possible.
lmoss
Message 8 of 12 (811 Views)
03-10-2010 07:14 AM in reply to: Mohamed_Yamani
I have a windows 7 64-bit user who is getting the same error just trying to create a new project. He is evaluating Plant 3D
as a potential replacement for a 3rd party product (Coade CadWorx) which fails to install on Civil3D 2010 64-bit - it is getting very frustrating.
Active Member
Mohamed_Yamani
Message 9 of 12 (811 Views)
03-10-2010 01:19 PM in reply to: Mohamed_Yamani
I couldn't fin a solution till now and I had to use virtual windows xp. I will wait another till we get V2011 and test. Edited by: Discussion_Admin on Mar 10, 2010 5:24 PM
EileenForan
Message 10 of 12 (811 Views)
03-10-2010 01:31 PM in reply to: Mohamed_Yamani
Mohamed_Yamani:
I don't know where you got your information about V2011, but your information is incorrect.
This forum is not the place to talk about future releases or about information you may have gotten from OTC.
Please refrain from posting regarding future product releases or product features that are not yet publicly available.
Thank you.
Eileen Foran
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
