AutoCAD Plant 3D Forum
Equipment Disconnect
4 REPLIES 4
thebearjed
580 Views, 4 Replies
every time i open a drawing all the piping that was connected to equipment is now disconnected (tear drop shows). i use PlantConnectJoint and reconnect everything, save, and close. reopen the drawing and everything is disconnected again!!!
what gives?????
4 REPLIES 4
Have you applied the new Plant 3D 2013 SP1 Data Integrity Hotfix? The issue you are having seems to be addressed in this hotfix.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21194788&linkID=14116968
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
i did install SP1 when it first came out but my computer went crazy and i had to uninstall Plant 3D and reinstall to get it back working.
I would encourge you to try again the update again. However, the link I sent you is for a very recent hotfix and I am sure this is not the same one you installed last time.
Quentin Contreras
in reply to: quentin.contreras
I have the same problem,
I have created isometrics, all references to equipment and connecting piping and the fasteners where good.
Now i open the plantdrawing again and all connections to the (xref) equipment are diconnected,
i have the latest SP installed (2013)
Even blindflanges on the equipment are disconnected.
”Boost
