I have create new project(custom made) and when I try to convert AutoCAD 3D block to Plant 3D I got this message. What is the problem?
Solved by martinTstewart_Adsk. Go to Solution.
Is the item you are trying to convert a Block? You might try to explode it and then try to convert it to see if that helps.
Quentin Contreras
Technical Support Specialist
My thought also. Start out with a named AutoCAD block.
In case you need it, here’s a brief outline of steps for creating a Plant 3D custom part from an AutoCAD block:
*Note: If you get “No ports information for block” message, this can be fixed by installing Service Pack 1 for Plant 3D 2014: AutoCAD Plant 3D 2014 Service Pack 1
Here's a short video demonstrating these steps.
(If this answers your question, please mark it as an Accepted Solution.)
