AutoCAD Plant 3D Forum
Elevation in ORTHOVIEW
8 REPLIES 8
Message 1 of 9
1390 Views, 8 Replies
Hi to all,
please, how may I input elevation of pipe in ortho view??
Can anybody help me?
thanks.
8 REPLIES 8
Message 2 of 9
ops...
I need elevation of "background of pipe"...
thanks..
Message 3 of 9
try using an ordinate dimension
Message 4 of 9
I need  backgroud  elevation pipe.
It's possible to do with "position ordinate", but only give's me  elevation at center pipe.
Thanks.
Message 5 of 9
Use ordinate dimension...not annotation
refer attached
Message 6 of 9
kylepope
Are you looking for a BOP dimension rather than a Centerline?
Kyle Pope
Process and Power Specialist
ECAD, Inc
Our Blog
www.pdoteam.com
Message 7 of 9
in reply to: kylepope
thanks for all your help. But isn't in front elevation my problem. I'm trying to find a way to get the same information (BOP) that I have in front elevation, but top view (plans), because in top view we doesn't have a line to make a "dimension ordinate".
So, there is a way to have a BOP in top view?
Like always , thank you for all your help.
Message 8 of 9
PeterQuinn
One of our AEs (Thanks Dag!) came up with this procedure. It's pretty involved but I think it does what you're looking for.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 9 of 9
in reply to: PeterQuinn
Great!!
Thanks.
This is the right way. But we need to change somethings.
Create Trigger BOP_TRIGGER_INSERT2
AFTER INSERT ON PipeRunComponent
BEGIN
UPDATE PipeRunComponent set EL_FT=round((select "Position Z"-MatchingPipeOD/2 from EngineeringItems where PnPId = new.PNPID),0) where PNPID=new.PNPID;
END
Create Trigger BOP_TRIGGER_UPDATE2
AFTER UPDATE ON EngineeringItems
BEGIN
UPDATE PipeRunComponent set EL_FT=round(new."Position Z"-new.MatchingPipeOD/2,0) where PNPID=new.PNPID;
END
__
”Boost
