i want to change the P3D catalog path from 2014 to 2015 by editing the pspx file. I use the method as described on http://www.pdoteam.com/2013/07/migrating-spec-catalog-references.
All needed paths are changed and saved, but when opening the new 2015 spec, catalog items are still loaded from 2014 catalog.
Is there something else to be changed?
regards, Jan
Solved by Dan.Scales. Go to Solution.
HI,
Rather than editing the CatalogReferences.xml that is located in the Editor folder try deleting the entire folder.
When you open the spec you should be able to browse the the correct catalog.
If the old catalog is still being referenced please try the following:
Replacing-catalog-links-to-a-spec
Dan
Hi Dan,
the problem is solved with the "Replacing-catalog-links-to-a-spec" workaround.
Jan
