If a project is started in Plant 3D can someone with a seat of AutoCAD P&ID only, access that project to edit the P&IDs? Does it update the correct database or do they need to be separate projects?
Solved by quentin.contreras. Go to Solution.
All you need to do is use the Open Project command in P&ID and point to the project.xml in the root project folder. Should work fine.
There is however a problem to be aware of when you upgrade to a new version. Any project that was ever opened in Plant 3D cannot be migrated using just P&ID. It must be migrated using the full Plant 3D versiom. Just an FYI
Brian Lund
PE CAD Operations-Plant Specialist
GEA Process Engineering
Brian.lund@gea.com
Yes, a Plant 3D project which contains P&ID drawings can be opened in a standalone version of P&ID and the P&ID drawings can be edited. Just make sure the user knows only to make P&ID changes and do not edit any of the Plant 3D information. Any project setup modification should be done in Plant 3D and not in the standalone version on P&ID.
Quentin Contreras
Technical Support Specialist
Quentin,
Can you elaborate on not doing configuration changes in P&ID under these circumstances? We modify the setup of a project all the time in P&ID and since our template projects originate on a machine using full Plant 3D are you saying this will cause a problem? We have not seen any problems as long as we confine the changes to P&ID and general project setup items.
Brian Lund
GEA Process Engineering, Inc.
brian.lund@gea.com
