I am trying to customize the description for a swage which has different End Types but, in the Edit Long Description dialogue the only available End Type is for Port #1. How can I get the End Type for Port #2?
The long description is for the part as a whole and not for an individual port. It is what will show up in the BOM when you make an iso. In that description the ports are described: BWXMPT for example. If you're trying to change port properties, see the attachment on catalog editor. You could copy a swage from the catalog that has the end types you want, and there you can change dimensions or the descriptions (circled in red on photo).
Hope it helps,
-Tony
Tony,
I am trying to customize the "Edit Long Description Styles" in the Spec not in the Catalogue. This is accomplished using component properties to create a new long description. Please see attachment.
