AutoCAD Plant 3D General DIscussion
Active Contributor
PLANToftheAPES
Message 1 of 11 (2,069 Views)
Edit Equipment Nozzles in Plant 2012
2069 Views, 10 Replies
10-04-2011 11:42 AM
We migrated from Plant 3D 2011 to 2012 and have the following issues with equipment nozzles:
1.  Equipment that was migrated from 2011, when we try to edit equipment nozzles, we do not get the "pencil". When we try to select the nozzle by itself, the whole equipment hilites.
2. The same thing happens with equipment that we create in 2012.
How are we suppose to select the nozzle on equipment in 2012 and edit these nozzles?
To edit the nozzle you should press control and select the nozzle, so the pencil will appear to edit.
Ricardo
ricardo.janesko
Message 2 of 11 (2,068 Views)
Re: Edit Equipment Nozzles in Plant 2012
10-04-2011 01:20 PM in reply to: PLANToftheAPES
Ricardo
Valued Contributor
dzine14u
Message 3 of 11 (2,009 Views)
10-14-2011 07:28 AM in reply to: ricardo.janesko
Thank you Ricardo...this was helpful to me as well.  However, I cannot find a way to DELETE a nozzle that was previously created without recreating the entire tank and nozzles from scratch.  How do you delete a previously created nozzle?
Chuck
Chuck Altmix
Lead Engineering Designer
Upper Consulting, Inc.
www.upperconsulting.com
ricardo.janesko
Message 4 of 11 (2,006 Views)
10-14-2011 07:51 AM in reply to: dzine14u
For you delete a nozzle, the procedure is the same. With the CTRL key you select the nozzle and click delete. If not, try to isolate the tank and repeat this procedure.
Ricardo Janesko
Valued Contributor
dzine14u
Message 5 of 11 (2,004 Views)
10-14-2011 08:41 AM in reply to: ricardo.janesko
Excellent!  Ctrl > Select Nozzle to highlight > DELETE
I was looking for a delete button AFTER clicking on the pencil to edit but instead of clicking on the pencil you just hit the delete button.  Thanks
Chuck Altmix
Valued Contributor
batone79
Message 6 of 11 (1,987 Views)
10-17-2011 03:23 AM in reply to: ricardo.janesko
HI, Ricardo I hope you can help me about this.
I created a Equipment and adding a Nozzle, I can not change Spec and Size, every time do the same Nozzle size and Spec.
How can I change Nozzle´s spec and size?
I show you in the img added to this post, where you can see in a Red box the spec to change for the Green box and don´t do it.
thanks.
Valued Mentor
Rich.O.3d
Message 7 of 11 (1,973 Views)
10-17-2011 05:31 PM in reply to: batone79
try clicking on the item you show in green box...it should turn blue to show it has been slected then apply and check again
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Contributor
batone79
Message 8 of 11 (1,959 Views)
10-18-2011 09:23 AM in reply to: Rich.O.3d
HI, thanks for your replay, thats works...thanks and sorry for the inconvenience...
New Member
dsheese
Message 9 of 11 (1,778 Views)
12-27-2011 11:39 AM in reply to: PLANToftheAPES
Has the original modify nozzle problem been solved? Where the nozzle doesn't highlight and the pencil doesn't appear. I can create equipment then edit the nozzles but later the edit procedure stops working.
Employee
TomislavGolubovic
Message 10 of 11 (1,770 Views)
12-27-2011 07:19 PM in reply to: dsheese
Are you pressing CTRL when you click on the equipment nozzle?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
