AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Dynamic Tool Palette
1 REPLY 1
phwatso
730 Views, 1 Reply
How do you turn OFF Dynamic Tool Palettes, each time you change spec and also on first use it locks the screen for several minutes whilst it re-builds the content.
1 REPLY 1
jason.drew
in reply to: phwatso
You can use the command "PLANTDYNAMICTOOLPALETTE" and set it to "Disable"
If you have any questions please reply back. If this is an acceptable solution, please click the "Accept as solution" button to help others locate this information during a search.
Thank you,
Jason Drew
Designated Support Specialist
”Boost
