How do you turn OFF Dynamic Tool Palettes, each time you change spec and also on first use it locks the screen for several minutes whilst it re-builds the content.
Solved by jason.drew. Go to Solution.
You can use the command "PLANTDYNAMICTOOLPALETTE" and set it to "Disable"
If you have any questions please reply back. If this is an acceptable solution, please click the "Accept as solution" button to help others locate this information during a search.
Thank you,
