Context : Project 2013 French resident on a server , multi users, SQLExpress, (big) file size #55Mo
Symptomes : (After some fatal crashes) :
- object properties are uncomplete (see attached)
- impossible to delete object
- after PLANTAUDIT command, all object are deleted with message like "... object connection to database not possible..."(see txt file attached)
Already tried :
- PLANTAUDIT
- Revover
- integration of the file into new project
- objects copy & paste in new file
Help please !
I'm ready to transfer the file to private Autodesk private ftp for rescue of this big file 😉
Sam
Tested with english version and SP2 2013 :
Same things, PLANTAUDIT result :
Erased component 186BE0 not linked to project database.
Erased component 186BE5 not linked to project database.
Erased component 186BEE not linked to project database.
Erased component 186BF9 not linked to project database.
Erased component 186C01 not linked to project database.
Erased component 186C06 not linked to project database.
The auditing process is complete.
Aborted network evaluation due to error: eWasErased"
and all P3D element erased .. :-((
Did you solve this?
I'm having the exact same issue in AutoCAD plant 3d 2013 SP2
If you know how to solve it please tell me
Hi Jose
I suppose than SP2 avoid to have new issues.
But what I understood from support : the SP2 don't repair damaged files. I confirm that.
The solution I fund was : copy & paste in a new file P3D object (but you lost the Pipelinegroup informations ...)
For new file I have not meet again the issue with SP2....
Regards
Thanks for replying
I tried copying the pipes but when i try to paste in another drawing it says
Failed to create Plant 3D object data for 1 components. These components could not be recreated.
and no components get copied only the annoations and flow lines get copied
what do you mean by copy & paste in a new file P3D object?
Regards
