AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Duplicate TAG Piping Specialty Item
3 REPLIES 3
M-JGP
1262 Views, 3 Replies
Cuando insertamos varios accesorios (Piping specialty items) el programa nos permite duplicar TAGS.
Es un error del programa?
Cual es la Solucion?
When inserting various accessories (Piping specialty items) program allows us to double TAGS.
It is a program error?
What is the Solution?
3 REPLIES 3
quentin.contreras
in reply to: M-JGP
This is actually part of the exisiting design of P&ID for piping specialty items. However, this has been passed on to our development team as a future enhancement request. The request ask for these tags to function in the same manner as valves do and not allow for duplicate tags.
If you would like to express to our developers why this feature is important to you, you can use the following feedback link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Any available solution for the duplicate tags issue?
I have the same basic query and this has been an issue for years but I would like to know if the documented workflow to fix the issue actually works with 2019 and 2020 moving forward.  The workflow albeit documented this October only refers to "AutoCAD P&ID 2012, AutoCAD P&ID 2013, AutoCAD P&ID 2014, AutoCAD P&ID 2015, AutoCAD P&ID 2016, & AutoCAD P&ID 2017"
not 2018 or later ( I am using 2018).
https://knowledge.autodesk.com/support/autocad-pid/troubleshooting/caas/sfdcarticles/sfdcarticles/Un...
”Boost
