in attempt to <recover> I get ( also get the same error after restarting the program )
AudoCAD Message
Program Errors were detected.
Recommend that you save your work and restart the program.
and any attempt to open the drawing, I get
FATAL ERROR: Unhandled Access Violatin Reading 0x965ba00 Exception at ee49d87fh
it was working fine yesterday, I have done no work on the file since it was opening correctly.
Audit project comes up with no errors ( with all files closed )
Recover does not work since I get the above error..
trying to open the drawing results in a fatal error...
so looks like I have to redo the entire drawing?
If you'd like to email me the file or post it if it's not to private, I can look at it. I'm also wondering if there is something in the data cache that conflicts. Have you tried clearing it?
I cannot really post it on an open forum, it's quite private right now with alot of copywritten material. the project folder is getting up there too 427 megs ( the dwgs alone are 279 megs )
I think I may have an idea of what happened.. I have 5 main files - smolt / juvenile / growout / building. and the growout is doubled for two systems. what I did was mirror the growout, and save the mirror to another file and added it to the project, then went through and re-tagged all the lines and equipment. *I do not think P3D liked that - and it is most likely the reason the file blew up on me as the OP*
Another issue that I just noticed, while using x-ref overlays to finish up tying up the systems is that not all of the files are at #0,0,0?! but in the building file, they all connect properly in P3D, but when I overlayed the building into a single file say smolt or juvenile, #0,0,0 was off by ~45ft on Y axis and ~80ft on X axiz?!?
so I am making daily backups of the project and I am hoping that I can finish the revisions and construction sheet set before the entire thing goes up in smoke.
I hope this is not normal for large projects?
John.
If you'd like to send the drawing to me via our website you can do that as well:
http://www.pdoteam.com/contact-us/send-files/
I'll talk to the boss and clear it.
John.
