We are field welding everything and they want isos that contain as much stuff on each sheet as possible. Turning down the packing is not an option, ecspecially since 90% of the other isos come out perfect. It's just that 1 in 10 is like this and if there was a way to control leader length it would be all good.
Solved by jabowabo. Go to Solution.
Look for 'BumperDistance' in the isoConfig.xml file. Reduce it and test as necessary.
Thanks for the reply. That shortens the leader by moving arrow toward the bubble. Would be nice if it did the opposite, move bubble closer to the arrow and whatever is being pointed at.
Changing a bunch of the settings in that theme/annotations section did not make a difference in how it looks. But are you saying that you can have SP1 and Extensions at the same time? The attached document describes the feature of extension 2 that should solve the problem and then some. But I was under impression that SP1 and subscription extensions were mutally exclusive. If they are not then it's really good news.
I really appreciate this. So if I understand your post right, those few machines did not have ext1 on them when you installed ext 2?
An attempt to install Ext 2 on P3D 2014 SP1 has not been succeful.
EDIT:however my advanced iso options box no longer has "force on one sheet" option and a new iso that used to have the above described problem, no longer has it and looks good.
If I recall correctly, you should not install 2014 SP1 before installing Ext 2. All of the fixes for SP1 are included in Ext 2.
For what it's worth, for 2015, we were able to make the installer smart enough to install extensions even with service packs installed.
About the "Force on one sheet". We changed the text. It now says something like "create split points automaticaly". If you uncheck this, it will do the same as Force on one Sheet. With Ext 2, it will respect this and not split under any circumstances.
WARNING. ONE MAJOR FAIL SIDE EFFECT OF THIS PROCEDURE DISCOVERED:
If you do this you will lose ability to edit and delete nozzles on P3D equipment. The pencil glyphs do not even appear over the nozzles of new equipment. Still have them on the equipment created prior to. Never mind; it works with nozzles on equipment converted from 3-d blocks, but not on the ones created in equipment dialog box. Will probably have to reinstall software. Jabowabo, I would really appreciate if you check if the machines with this installation are able to select and edit nozzles on newly created equipment.
Thanks.
Thanks Peter,
I will lobby the management for an upgrade to 2015. In the meantime is there anyway to remove ext 2, remove sp1, and then apply ext 2 w/o doing a full software reinstall?
No problems editing nozzles here (holding ctl while selecting nozzle). If you uninstall, be sure to uninstall ext 2 first as it will not uninstall after Plant is uninstalled.
