AutoCAD Plant 3D General DIscussion
Active Contributor
cbeinecke
Message 1 of 3 (101 Views)
Discard of color
101 Views, 2 Replies
07-14-2011 09:44 AM
I have an issue with the color of some Plant 3D objects. Especially with stubends and valves. When they are inserted the don't appear in the color which is assigned to them. Even changing the color in the properties palette is ignored. Sometimes the valves have the right color and sometimes not. Even though it's the same valve. Stubends always appear white.
Is this a know bug?
Carsten
Product Support
jason.drew
Message 2 of 3 (97 Views)
Re: Discard of color
07-14-2011 01:22 PM in reply to: cbeinecke
We've had some issues with this as well. It seems to happen with custom content or block based components. It retains the color set inside the block and once it's converted, the color cannot be changed.
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Active Contributor
cbeinecke
Message 3 of 3 (81 Views)
07-14-2011 09:49 PM in reply to: jason.drew
Hi Jason,
thanks for the feedback. This could be part of the problem and I will test it with the customers specs and catalogs.
Carsten
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
