I recently had a fatal error. When I restarted AP 2014 and started routing pipe I now get dimensions and angles that show up next to my pipe. I find this rather annoying and also noticed that now my point filters don't work. Does anyone know how to turn this off?
Solved by yama21250. Go to Solution.
Dynamic Input Off, and point filters?? Did you mean snap?? just hit F3 or type osnap for the setup. Thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
It looked as if my dynamic input was already turned off but I had to click the button twice, once to turn it on (even though it was already on) and once again to turn it off. It seemed to work fine after that.
Brian
