Is there possibility make make correct dimensioning to ortho which has been made in SW direction (or NE etc). Now dimension wont show correct value
Solved by PeterQuinn. Go to Solution.
The process for making an ortho flattens out the view to 2D. For an iso view direction, it might look like 3D, but it's not anymore*. So, there's not enough information on an isometric view to do correct dimensioning.
If dimensioning is more important to you than having a flat drawing, just create a paperspace viewport of your 3D model.
*if you open the view up in model space, you can see the flattened drawing.
