Hello!
I have the same problem: while modelling in plant 3d the dimension boxes do not appear. All that appears are the leader arrows and the leader lines, but no dimension in which i can specify an exact number!! Also even if I select my ball valve, or other element, and try to move it the dimensions do not appear.
How come is this happening out of the blue?
Thanks.
I was not refferring to Dynamic Input, I was referring to the fact that I can no longer precisely locate/relocate my parts (eg: ball valve) since after selecting it I cannot see the two usual dimensions, one from upstream to the middle point and the other from middle point to downstream, to of course, the next intersecting element.
Dymanic input it's a copy of the Command Line located for easy visualising near the mouse pointer. The dimensions that I'm talking about are those othogonal to the pipe/element that you work with. It's a visual aid.
Another eg: when you put a ball valve on a bypass two dimensions apper: one from upstream elbow the other from the downstream elbow and they meet in the middle of the ball valve. You the have the option of pressing Tab key and swithching between those two, for a correct positioning.
Thanks.
Yes, that is exactly what i'm referring to!
However, see the attached picture that Dyn Input in on but I just found out that even if I press the button or the F12 key, the command line does not show any modification about the ON/OFF status!!!
So I gues it's a registry thing?
Thank you for your quick reply.
