AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Dim Styles
1 REPLY 1
universalpiping
388 Views, 1 Reply
Dim Styles
I cannot  seam to change my dimtxt size seperately from the rest of the text in my isometric drawings.  If you open the titleblock editor and go to dim styles you can change the text size from .0938 to whatever you want, the problem is it doesnt just change the dimension lines text, it also changes the bill of material text size.  What can I do if I just want to change the text size of the dimension lines?
Intel(r) Xeon(R) CUPI E3-1505Mv5@2.80ghz
32 gb ram
win 10 x 64 bit OS x64 based processor
Autocad Plant Design Suite Ultimate 2017
1 REPLY 1
in reply to: universalpiping
We are also experiencing the same situation with the text sizing.  In our case we would like the annotation on the Isometric (Line Number to be specific) to be larger, but do not need any other text to change it's size.
Tags (2)
”Boost
