AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
DIM SCALE LINEAR - Not consistent across a single viewport
17 REPLIES 17
Message 1 of 18
TRdesigner82
2835 Views, 17 Replies
Can someone explain to my why the Primary Units Dim Scale Linear changes depending on what I attach a dimension to? This is very problematic for me. Sometimes it'll change with an Update View even. This isn't something that should be happening because the potential to have drawings going out with grossly inaccurate dimensions if very high? Please help!
17 REPLIES 17
Message 2 of 18
TRdesigner82
in reply to: TRdesigner82
See attachment for clarification...
Message 3 of 18
TRdesigner82
I'm not able to get the attachment to work. Had the same problem last time to used this forum...
Message 4 of 18
Hopefully the attachment issue you’re having will clear up soon. I tested with an attachment here and it appears to work.
You may want to consider creating a quick video using Autodesk Screencast. This could help in getting better responses (since the Discussion Forum Community can see clearly what you’re dealing with in the video).
How to use Autodesk Screencast to document a support issue
You don’t have to attach the video, just post the link to it when ready.
Martin Stewart
AEC Support Specialist
Message 5 of 18
https://screencast.autodesk.com/Main/Details/8411eb55-a118-47a6-9add-be40a6f43dd7 All I did here was take a set of dimensions and stretch them up a little. The result of that is that the DIM SCALE LINEAR value goes from -32 to 1024. Why would that happen? I can't understand why you'd want it to change?
Message 6 of 18
I've replied to this post with a link to the video twice now and still it doesn't show up. Has anyone else been having issues with attachments or just replying to a post?
Message 7 of 18
Maybe trying a different web browser would help. Using Chrome, I was able to add that attachment earlier.
Martin Stewart
Message 8 of 18
Message 9 of 18
Sorry I missed your phone call Martin. I looked into what you said and it doesn't appear that the dim scale is changing. The only properties that are different between the 2 and shouldn't be are "Associative" and "Dim Scale Linear". The good dimensions lists them as "No" and "-32" respectfully. The dimension that is showing incorrectly is listed as "Partial" and "1024". If I type DIMSCALE at the command line it's set to 1 and my dimstyle is set to the same thing (FULL) for both dimensions.
Message 10 of 18
TRdesigner82
I also found this old post that seems to be about the same thing... http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Objects-move-dimension-locations-aren-t-maintai...
Message 11 of 18
JohnHolder
What web browser are you using? anything other than Internet explorer has issues... well internet explorer has the least amount of issues.
I read the forum with chrome, but If I have to post, I have to load up IE.
*edit* or when I forget and post with chrome I usually have to load up IE and fix the post.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Message 12 of 18
TRdesigner82
in reply to: JohnHolder
I used to use Internet Explorer with no problems but then a while back our IT guy said we should all start using something else and suggested Firefox. When I had this problem I switched to Chrome and it seems to be better but I still can't access the Options at the top of each post. I'll test out Internet Explorer again.
Message 13 of 18
Are you able to post attachments now? It would be good to be able to look at the DWG you based the video on.
Martin Stewart
Message 14 of 18
Depends on if it comes through with this. If not I'll have to try Internet Explorer.
Message 15 of 18
TRdesigner82
Trying with Internet Explorer...
Message 16 of 18
TRdesigner82
I tried to attach the dwg using Chrome and Internet Explorer and it wouldn't come across using either.
Message 17 of 18
I’m not sure why these partially associated dims are changing the Dim Linear Scale on you when you adjust them. It may have something to do with the history or source of the drawing(?)  However, I noticed that when adjusting the non-associative dimensions at the column lines it doesn’t do this.
So the solution here is to make those dimensions non-associative before you adjust them.
This can be done with the command DIMDISASSOCIATE.  To Disassociate a Dimension
You may also want to change DIMASSOC to 1  DIMASSOC (System Variable)
(If this answers your question, please mark it as an Accepted Solution).
Martin Stewart
Message 18 of 18
Is this still the only solution to this? It really isn't very practical and this issue shouldn't happen if the first place. If I set the DIMASSOC to 1 I get the paperspace distances not the actual measurment. Has anyone else found a better solution/workaround for this???
”Boost
