Difference between shape and line model, I start with a shape model, I convert lines to members, then I streched the members, but after streching the line model is differend, can somebody help?
Were you able to find a solution for the line model displaying as it was?
If you are working with AutoCAD Plant 3D 2014 have you installed the latest Extension or Service Pack? Just remember that if you have Extensions loaded, do not install the Service Pack. If you are current you will either have Extension 2 installed or Service Pack 1. Extensions are only available to subscription customers and can be downloaded from Subscription Center. The Service Pack 1 for Plant 3D 2014 can be dowloaded here.
AutoCAD Plant 3D 2014 Service Pack 1
Quentin Contreras
Technical Support Specialist
