When I try to add a flange to xref Equipment , I have a message
"PnPcompletionStatus.RowNotFound"
Look at picture...
Milic
I have the same issue, with slines atm. pops up 4-5 times and doesnt connect well with other slines
Was there an answer to the question?
I can give you some background into the cause of this issue. The database for the project is missing record rows so a warning is being displayed.
Typically this occurs when a drawing from a different project is copied in. If the other project contains custom properties those property definitions are stored inside the drawing itself, but the project you are using doesn't know about it.
Here's a quick way to sych up your current project with the properties contained inside the drawing. This is assuming you have not copied the drawing into the project yet:
1. Use the PNPDWGDATABASEBLOBMERGE command and set the value to OFF
2. Copy the drawing into the project
3. Use PNPDWGDATABASEBLOBMERGE command again and set the value back to ON
In this case where you are already seeing the error, you would need to remove the drawing from the project, set the PNPDWGDATABASEBLOBMERGE to OFF, copy it back in, then turn it back ON.
One of the drawings in our project desplays the attached error every time we save. The dwg seems to save as it should so I havn't worried too much about it. Just wondering if it's going to cause any issues down the road?
If you have added any custom properties, you'll have to purge the cache on any machines that had project drawings open prior to the add.
Something else has to be causing it then because we run that pretty regularly. I've even addad a desktop icon for it so others are more likely to use it too. Still get the error though.
