AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Desig Problem - With connections
11 REPLIES 11
Message 1 of 12
milic.srdjan
1256 Views, 11 Replies
When I try to add a flange to xref Equipment , I have a message
"PnPcompletionStatus.RowNotFound"
Look at picture... Smiley Happy Smiley Happy
Error
Milic
11 REPLIES 11
Message 2 of 12
jason.drew
in reply to: milic.srdjan
Have you added any new custom properties to the Plant 3D classes in project setup? Thanks,
Jason Drew
Designated Support Specialist
Message 3 of 12
asmeltzer
in reply to: jason.drew
I have the same issue, with slines atm. pops up 4-5 times and doesnt connect well with other slines
Was there an answer to the question?
Message 4 of 12
jason.drew
in reply to: asmeltzer
I can give you some background into the cause of this issue. The database for the project is missing record rows so a warning is being displayed.
Typically this occurs when a drawing from a different project is copied in. If the other project contains custom properties those property definitions are stored inside the drawing itself, but the project you are using doesn't know about it.
Here's a quick way to sych up your current project with the properties contained inside the drawing. This is assuming you have not copied the drawing into the project yet:
1. Use the PNPDWGDATABASEBLOBMERGE command and set the value to OFF
2. Copy the drawing into the project
3. Use PNPDWGDATABASEBLOBMERGE command again and set the value back to ON
In this case where you are already seeing the error, you would need to remove the drawing from the project, set the PNPDWGDATABASEBLOBMERGE to OFF, copy it back in, then turn it back ON.
Jason Drew
Message 5 of 12
TRdesigner82
One of the drawings in our project desplays the attached error every time we save. The dwg seems to save as it should so I havn't worried too much about it. Just wondering if it's going to cause any issues down the road?
Message 6 of 12
jabowabo
in reply to: TRdesigner82
If you have added any custom properties, you'll have to purge the cache on any machines that had project drawings open prior to the add.
Message 7 of 12
TRdesigner82
in reply to: jabowabo
You talking about PnPLocalDataCachePurger.exe?
Message 8 of 12
jabowabo
Yep
Message 9 of 12
jabowabo
If the cache data tables don't contain the new prop column you will get an error as you show. However, there may be other causes for this error also...
Message 10 of 12
TRdesigner82
Something else has to be causing it then because we run that pretty regularly. I've even addad a desktop icon for it so others are more likely to use it too. Still get the error though.
Message 11 of 12
jabowabo
Have you tried Jason Drew's fix above?
Message 12 of 12
TRdesigner82
No, I haven't. This is the only Plant 3D project we have so far. Plus its a piping drawing so at this point if I were to copy it out then back in we'd loss all our pipe and instrument tags. If the error isn't going to cause any problems I'm not sure its worth worrying about now.
”Boost
