i have a spec with two 4" b'fy valves (for instance). each have a different acuuator. how do i set one of the two to be placed by default when placing the valve?
very new to this btw.
brn
You need to set the part priority in the spec:
under the valve section in the spec, i have b'fly, check and gate valves. setting priority only lets me set which valve type....not the priority for a particular type..say within b'fly valves where there are examples with different operators.
i'm trying to set a priority for instance, which of the b'fly valves is placed by default.
brn
