AutoCAD Plant 3D General DIscussion
Valued Contributor
3 Kudos
Post 1 of 15
Data Manager - Project Reports
829 Views, 14 Replies
07-26-2012 05:29 PM
We have around 25 drawings of P&ID. And because of the client, we need to produce very detailed schedule based on P&ID. It is made easier with the Plant 3D Project Reports, of course. But since we have too much items to be managed. And with this particular client, we need to highlight the new and deleted item in every revision Is anyone know how to order the Project Reports? At the moment, it seems to only ordered based on PnPID. We like it to ordered based on drawings number than the valve number, for example. You can't really do this on the direct output of excel file. A lot of function of excel is disable with the direct output. We have quite a lot of schdules and items to deal with. If I can order the direct output, that can save a lot of time.
If you're using Project Reports to generate the output, you can manually edit the .xml report templates and sort by any columns you like.
Here's a snippet from the ValveList report to order the output by Drawing Name and then Valve Tag.
<?xml version="1.0" encoding="utf-8"?>
<PnPQueryDefinition xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<OrderBy>
  <PnPSortItem>
    <SortDirection>Ascending</SortDirection>
    <SortColumn>Dwg Name</SortColumn>
  </PnPSortItem>
  <PnPSortItem>
    <SortColumn>HandValves.Tag</SortColumn>
  </PnPSortItem>
</OrderBy>
<GroupBy>
  <string>PnPID</string>
</GroupBy>
Hope this helps.
Andy
Employee
39 Kudos
Post 2 of 15
Re: Data Manager - Project Reports
07-27-2012 10:02 AM in reply to: Arch_art
A couple of ideas - You can sort the report by any field by clicking on the header.
Or, if you could use the external Report Creator program to generate your reports.
Peter Quinn
Senior Product Manager
Valued Contributor
3 Kudos
Post 3 of 15
07-28-2012 06:12 AM in reply to: PeterQuinn
Hi, Peter Thanks for reply. I do understand that one can sort the field, but that is only when one view it in Data Manger. No matter how I sort it when I view the data in Data Manger. The exported the excel is always sorted based on PnPID. I didn't find any setting that can help with this in Plant 3D so far. (Plant 3D 2012 is what I used.) I also checked about the Report Creator before, But I understand the Report Creator only allow you to create the report, not export to excel and read back? Moreover, I believe that Report Creator doesn't allow you to union the class like Access. With the report that we are creating, we need to union some of the class. With the amount of information we deal with, we need to be able to export to excel, put in the informations and import back to Plant 3D. Let me explain why I have to do these. 1. P&IDs are always changed during the design process. There are new valves, instruments added. Some valves, instruments are deleted. This is happened like every week. In order to make sure the information is not missed or wrong, we are export the schedule, edit it and put back to plant 3D database (This is the process filling the data for schedules). 2. in every submission of schedules to the client, the number of items in Data Manager is always different. It is needed to identify the new one, deleted one, etc. With the PnPID number order output, it just very hard to find the information, understand the data. That's why we think about sorting the excel output of the Data Manager. 3. during the life the design, there might be different engineers who process the schedules. 4. excel file outputted from Data Manger is not allowed to sort and some of the other basic excel function. In order to sort the data, we had to copy the whole sheet out and copy to a new sheet, edit it and copy it back, time consuming and dangerous. So, we are thinking, it is easier to have the excel output ordered as we needed to speed up the process. Cheers, Peggy -- Best Regards, Peggy Lin
Valued Contributor
14 Kudos
Post 4 of 15
07-30-2012 09:10 AM in reply to: Arch_art
<OrderBy>
  <PnPSortItem>
  </PnPSortItem>
  <PnPSortItem>
  </PnPSortItem>
</OrderBy>
<GroupBy>
</GroupBy>
Hope this helps.
Andy
Valued Contributor
3 Kudos
Post 5 of 15
07-30-2012 03:19 PM in reply to: andy.davis
Hi, Andy
Thank you for your GREAT help. That is working. and will save up a lot of time. I didn't realize that report format is also controlled by xml file.
Looks like the report table query is also controlled in xml. Do you know how can we union the class for present here? is this possbile? How is this xml work? Please point out where I can find the information to learn from.
Cheers
Valued Contributor
3 Kudos
Post 6 of 15
07-30-2012 03:40 PM in reply to: andy.davis
Hi, Andy
Can we do one step furthur:
I notice that the number that outputed from data manager in excel is regarded as a TEXT instead of Number, is there anyway that we can make it as number?
This effect the result of sorting:
When it save as text, the sorting is like this, e.g.
2354
245
365
456
what I like it to be is:
245
365
456
2354
Please help!
Cheers
Valued Contributor
14 Kudos
Post 7 of 15
07-31-2012 02:02 AM in reply to: Arch_art
Yes, you can UNION tables together, please see attached example that reports 4 specific types of valve.
Please be aware that you cannot edit this report through the Project Setup UI, but it will preview.
The datatype in Excel depends upon the original datatype in the P&ID database - the value column in the example is  defined as a number and is output as such to Excel.
I don't have any documentation to share with you regarding the xml schema, sorry.
Andy
Valued Contributor
3 Kudos
Post 8 of 15
07-31-2012 06:32 PM in reply to: andy.davis
Thanks, Andy
The example you are given can be simplify as:
( "ball valve" Union " Butterfly Valve)  Union ( "Gate valve" Union "Inline Valve")
What if I need to union "Control Valve" (Instrument Class) & "Knife Gate Valve" (Hand Valve Class), Can this work? I am thinking, with same property, like valve number, in Control Valve is "Loop Number", but Gate Valve is "number". Does it need to rename one of them to be the same with the other one, If we can do something similar in SQL. do somehting like "Loop Number AS number" . Or this doesn't matter at all? As long as there are listed in the order we needed, it will union it?
With the Report number order, I had a look my setting. The Loop Number is "number" type, but the sorting in the Project Report regarded as text. Maybe there is no way we can do anything about it.
Valued Contributor
14 Kudos
Post 9 of 15
08-02-2012 01:20 AM in reply to: Arch_art
If you use the fully defined UNION (as per my example) you can 'mix and match' the fields you extract from each table so long as the fields in the <SelectList> are common to all tables.
I have updated the example to include the ControlValve class extracting the ActuatorType and LoopNumber into the Comment and Value fields in the <SelectList>.
If you have any undefined values in the LoopNumber field (showing as ??) the column will be treated as text.
Andy
Valued Contributor
3 Kudos
Post 10 of 15
08-07-2012 06:19 AM in reply to: andy.davis
Hi, Andy
Thanks for you information. I tried the mathod that you showed in your example. I come up with this, but it didn't UNION two table for me. In the data manager, I can only see the information from FlowmeterMass table. What did I do wrong? Please see the attachment.
Cheers,
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
