AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Dashed or Hidden lines in Orthos for UG Piping
7 REPLIES 7
Message 1 of 8
JoeKay
834 Views, 7 Replies
If I set all my underground piping in the model to a hidden (dashed) line type, then run an Ortho, the lines do not carry over. Is there a way to do this yet? Is there a setting I'm missing or an easy work around versus exploding the ortho lines and manually changing them? I'm currently working in Plant 13, last project till 14. Please tell me you can do this in 14. Thanks
7 REPLIES 7
Message 2 of 8
dave.wolfe
in reply to: JoeKay
Have you tried changing the viewport layer settings in the 2013 ortho? Yes, in 2014 this is easy.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 3 of 8
JoeKay
in reply to: dave.wolfe
Unfortunitly our pipe is layered by number. So if a line number is above ground and below ground that wouldnt work. Thanks.
Message 4 of 8
dave.wolfe
in reply to: JoeKay
Make two viewports, and overlay them. One shows the UG, ones shows above ground.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 5 of 8
JoeKay
Thats certainly out of the box. I like your style. I would of never thought of that. I'll give it a shot. Thanks.
Message 6 of 8
JoeKay
in reply to: JoeKay
Unless I'm missing something, that still wouldnt work. If I overlayed them, one with hidden lines, other with not. I still wouldnt be able to isolate the other section of piping. Cause like I said my whole pipe run is the same line number, hence same layer number. I cant turn one hidden and the other not. I've tried what you sugested, maybe I'm not thinking exactly what youre trying to get across.
Message 7 of 8
dave.wolfe
in reply to: JoeKay
Did you change the level of the clipping plane? Making the UG clip at the top of slab should isolate the portion below ground in the UG viewport.In the AG viewport, make the bottom of the clip top of slab.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 8
JoeKay
That makes sense. I wasnt thinking in that dimension. Thanks again.
”Boost
