AutoCAD Plant 3D General DIscussion
Distinguished Contributor
20 Kudos
Post 1 of 6
Accepted Solution
CUT Problem
384 Views, 5 Replies
05-10-2012 01:51 PM
Hey,
This is something that since always happens to me.
When I'm in perspective view with a short focal length like 20mm, objects that are closer are cut of vision.
Look the attached image.
Is there any way to fix this?
Hey,
After a few years I found the solution to this problem.
Whenever I asked someone about this problem, they thought I was talking about the 3DCLIP command. But it is not.
There is a variable called: PERSPECTIVECLIP
The default value is 5.
I thought it a good value to avoid clipping is 0.01
Look the difference between them, check annex.
Att.
Gabriel Nogueira.
20 Kudos
Post 2 of 6
Re: CUT Problem
05-21-2012 07:56 AM in reply to: Gabriel.N
Someone, somebody, anyone knows how to fix this?
Product Support
35 Kudos
Post 3 of 6
Re: CUT Problem
05-31-2012 02:45 AM in reply to: Gabriel.N
I can't reproduce this issue.
The first thing to try is an update of your graphics driver.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Dan
Dan Scales
Employee
13 Kudos
Post 4 of 6
Re: CUT Problem
05-31-2012 05:57 PM in reply to: Gabriel.N
This happens when trying to view the model in perspective while clipping is on. If you turn clipping off it will go away. This is not a Plant 3D issue. It is an AutoCAD function.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
New Member
0 Kudos
Post 5 of 6
Re: CUT Problem
06-01-2012 01:05 AM in reply to: Gabriel.N
That's been a very frustrating problem for me also, thanks for clearing that up!! :smileyhappy:
20 Kudos
Post 6 of 6
Re: CUT Problem (CLIPPING PROBLEM)
02-24-2014 02:57 AM in reply to: Gabriel.N
Hey,
Att.
Gabriel Nogueira.
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
