Hey,
This is something that since always happens to me.
When I'm in perspective view with a short focal length like 20mm, objects that are closer are cut of vision.
Look the attached image.
Is there any way to fix this?
Solved by Gabriel.N. Go to Solution.
I can't reproduce this issue.
The first thing to try is an update of your graphics driver.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Dan
Hey,
After a few years I found the solution to this problem.
Whenever I asked someone about this problem, they thought I was talking about the 3DCLIP command. But it is not.
There is a variable called: PERSPECTIVECLIP
The default value is 5.
I thought it a good value to avoid clipping is 0.01
Look the difference between them, check annex.
Att.
Gabriel Nogueira.
