In the Cut Piece List the end of the pipes are showing "SQUARE CUT". I believe that should appear beveled.
Checking the pipes's properties I found "PL" at both ends, which I believe means "Plain End".
I was not aware of it until now, my 3d modeling is complete, there is any practical way to change this information to (BV) Beveled?
It would be possible to translate the end type information to my language too?
See the attached picture.
Att.
Gabriel Nogueira.
Solved by Gabriel.N. Go to Solution.
I found a solution:
In the file "isoconfig.xml" there is a part for setup.
I modified the first value that is the generic for the cases not listed, for example PL.
And also translate the others to the local language.
<!-- Pipe connection to condition map -->
<!-- A table which maps a pipe connection to a pipe condition. The pipe connection information is read -->
<!-- form the 3D piping model, and the pipe condition is the value that is displayed in the cut-piece list. -->
<PipeConnectionToConditionMap>
<Item Key="" Value="Chanfrada" />
<Item Key="SW" Value="Ponta Lisa" />
<Item Key="BW" Value="Chanfrada" />
<Item Key="BS" Value="Flared" />
<Item Key="FA" Value="Flared" />
<Item Key="SC" Value="Roscada" />
</PipeConnectionToConditionMap>
See the attached pictures.
Att.
Gabriel Nogueira.
