AutoCAD Plant 3D General DIscussion
Active Contributor
sergej.dezelak
Message 1 of 6 (497 Views)
Custom Valve Catalog
497 Views, 5 Replies
12-18-2013 01:17 PM
I have made custom valve catalog, with complete new components. I create blocks for each size of valve, make 2 ports with PLANTPARTCONVERT. Its work perfect on my computer.
But when I copy this template project (also catalog and pipe specs are coppied), to other computer the valves does not work. Other fittings is working, but valves not.
How this connection between catalogs and Plant 3D software working? Is there some path? relative or absolute?
thanks.
dave.wolfe
Message 2 of 6 (468 Views)
Re: Custom Valve Catalog
12-19-2013 05:52 AM in reply to: sergej.dezelak
When you create custom parts, the spec editor saves the source blocks into a folder called CatalogSupportFolder in the content folder (like C:\AutoCAD Plant 2014 Content\CatalogSupportFolder\. This folder needs to be copied to the user's computer as well.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Active Contributor
sergej.dezelak
Message 3 of 6 (452 Views)
12-19-2013 12:35 PM in reply to: dave.wolfe
Thank you Dave.
One more question. I have copy this catalog to other location (in the template project folder). Can I copy this folder now here, or it has to be on location C:\AutoCAD Plant 2014 Content\... ?
dave.wolfe
Message 4 of 6 (434 Views)
12-20-2013 06:13 AM in reply to: sergej.dezelak
It doesn't do any good to put it with the project. The folder has to be copied wherever your plant content folder location is set.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Distinguished Contributor
TRdesigner82
Message 5 of 6 (396 Views)
12-23-2013 05:44 AM in reply to: dave.wolfe
What if your shared content folder is located on a shared network drive? They should be able to see it after the copy then though right?
dave.wolfe
Message 6 of 6 (388 Views)
12-23-2013 07:06 AM in reply to: TRdesigner82
Yes.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
