AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Custom Valve and operator
4 REPLIES 4
1386 Views, 4 Replies
I have created Custom Valve by Custom - AutoCAD DWG Block based graphics. I can't add any operators in Valve Operator Mapping and also in Model and in Spec Editor. Whay?
4 REPLIES 4
batone79
You need to create first a valve as "Valve Body" not as "Valve"
Check this!
in reply to: batone79
It still does not work.
I did it this way.
batone79
I don´t Know but I Explain You how I do..
1.- Created two 3D Blocks in ACADP3D. One of them a Valve and other Actuator.
2.- To convert it into Catalog, Plantpartconvert and select the valve and Selected two ports / Exit
3.- For Actuator same action without ports, only Plantpartconvert select actuator block and Exit.
Into Spect Editor.
Make a valve Selecting Custom parts/Valve Body/....
For Actuator Selecting CustomParts/Actuators/....
thats it..
You have a CustomPart Valve and Actuator To.
It is working. Thanks.
Can I use sam other default Acutator for my CustomValve? Or do I have to use just CustomValve with CustomActuator ?
”Boost
