AutoCAD Plant 3D General DIscussion
New Member
joachim.oelschlagel
Message 1 of 9 (932 Views)
Custom Stub-in to elbows
932 Views, 8 Replies
01-24-2013 12:03 AM
I have tried to make stub-ins in elbows for long thermo wells since 2011 release, and it seems like it's still not possible in 2013 release. Someone knows of a workaround to this?
Snip below illustrates where i would like to make the stub in: (Note that it's not connected in my example)
Click the + grip off the corner of the elbow, hit S for Size and enter the size you want.   THe insertion options are somewhat limited, but you can use the connectionoffset option to move it up our down on the elbow.
dave.wolfe
Message 2 of 9 (919 Views)
Re: Custom Stub-in to elbows
01-24-2013 06:46 AM in reply to: joachim.oelschlagel
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Member
liuyong816
Message 3 of 9 (895 Views)
01-24-2013 05:29 PM in reply to: dave.wolfe
Hi dave:
     I want to show the connection offset value on the iso to reduce the counculation work from the connection coordination, is there any possible way to config?
     Thanks a lot !
Active Contributor
Layout-Bob
Message 4 of 9 (865 Views)
01-27-2013 11:17 PM in reply to: joachim.oelschlagel
Thanks Dave,
I managed to get it right on a horizontal pipe that turns upwards. Then I tried on a horisontal bend (which did not work), and then I tried to continue on the first pipe run (see attached picture).
In both cases I use your method with "connectionoffseT" and I use distance: -((Bend radius)/2)
Slightly confused :smileyfrustrated:
Active Contributor
Layout-Bob
Message 5 of 9 (856 Views)
01-28-2013 01:22 AM in reply to: Layout-Bob
Hmm.
Seems like the original post were posted from my suscription-center login which is my real name.
Regards
Joachim
dave.wolfe
Message 6 of 9 (847 Views)
01-28-2013 07:10 AM in reply to: Layout-Bob
Yea, it doesn't seem like there are enough options on the offset.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
New Member
kaisakol
Message 7 of 9 (700 Views)
05-27-2013 05:43 PM in reply to: Layout-Bob
Thank you.
Active Contributor
Jan-TSpD
Message 8 of 9 (70 Views)
12-11-2014 12:44 AM in reply to: dave.wolfe
is there a solution for this issue in P3D 2015? I want a stub in on an elbow to be on a certain elevation as shown in attached image.
A lot of placement settings are available, but i don't see the right one for this one.
regards, Jan
patpat79
Message 9 of 9 (20 Views)
12-17-2014 07:11 PM in reply to: Jan-TSpD
havent you tried using route pipe, then snap to nearest?
Best Regards,
Pat Andres
Autodesk Expert Elite
CAD System Engineer
Freelancer
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
