AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Custom Property from Catalog Editor to 3D Model
2 REPLIES 2
643 Views, 2 Replies
Is anyone aware of a way to bring a custom property created in your Catalog Editor (even Spec Editor) to be brought across to your model?
I came across this article:
http://blogs.rand.com/architectural/2012/10/custom-catalog-properties-for-plant-3d.html
However I cannot seem to get the values I have created to come across from the Spec Editor to the Plant 3D piping Model.
Example, I wanted to create a custom property in Spec/Catalog Editor called PipeID, which will show values of the ID of piping components.
I imagine this requires some sort of XML editing to get this "mapping" right?
Any pointers would be appreciated.
Thanks.
2 REPLIES 2
Peter_Jansoone
If you create properties with the same name (100 % exactly !!) in catalog, spec and project, the information wil flow through.
If it doesn't work, try a name wthout characters 'ID' in it, that might trigger special actions.
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
in reply to: Peter_Jansoone
Hi Peter
Thanks, your second suggestion seemed to work.
I tried changing ID to "LinerDiameter" and it seemed to bring the values across. As you mentioned, "ID" may have another trigger associated to it.
Thanks very much
”Boost
