AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Custom parts for instrument
3 REPLIES 3
dennis_thol
750 Views, 3 Replies
I'm working on a projekt in 3d Plant 2011. I've read all topics on this site about this problem and noticed a few other had the problem. I'm creating custom parts for instrument, but have iso failiure.
I have made models that is basically a pipe wich is the same size as I'm going to use and a pressure transmitter sticking in to the pipe, converted to plant part (plantpartconvert), added ports, then I made a new component (valve), added the model to it. I read another post that you could do this and use Iso type = Instrument-Dial and Skey = IDFL and then add to spec and update.
My problem is when making ISO:s the line brakes and I get "Error 2022: IDFGEN has detected a disconnected pipline.." and it's where my part is.
I've tried to change Skey to IDBV because I've got no flanges but no different.
Anyone got this problem and got it fixed or know how? Maybe I missed something in the process.
Thanks for any help!
Dennis Thol
3 REPLIES 3
Venkatesan.A
in reply to: dennis_thol
Dennis,
Could you please post a snap shot?
A picture would give more insight.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
It sounds like a Joint Settings issue. Have you added the end types to the joint settings so it knows to connect to it?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
dennis_thol
in reply to: Venkatesan.A
This is from catalog editor and the model
”Boost
