Since the 2012 version is almost here. I re-installed the autocad Plant 2011 demo version to suggest it to my superiors. Currently we do not use programs of this kind.
One of the things that I should demonstrate is that we will be able to use our blocks library.
To do this I decided to create a metric Project and create a custom part
The steps that I followed are:
The problem that I have is that I can not connect any other element to the custom part created
See pictures attached.
I followed the steps suggested on the help and I do not find what I am doing wrong.
Could you help?
Thank you in advance.
Max
I have a same issue and I did what you mention here. but how can I change type of spec when I import custom block.
