AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Custom Object Color
3 REPLIES 3
462 Views, 3 Replies
Custom Object Color
I have a problem with custom objects color. When I create an object in Invetor and than import it as an AutoCAD block to Plant or when I simply download it, Layers and Color settings from Project setup doesnt work. When I click on properties, object has assigned layer and color, but visually it is in same color that it was imoported.
3 REPLIES 3
jabowabo
Change the entities (explode all nested blocks if necessary) inside the block to layer 0 and color 'by block' before converting to a Plant 3D component.
in reply to: jabowabo
Thank you very much, It´s working
But yet I have a problem with Inventor objects
”Boost
