I have a problem with custom objects color. When I create an object in Invetor and than import it as an AutoCAD block to Plant or when I simply download it, Layers and Color settings from Project setup doesnt work. When I click on properties, object has assigned layer and color, but visually it is in same color that it was imoported.
Solved by jabowabo. Go to Solution.
