AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Custom component showing up skewed & wrong size on iso
3 REPLIES 3
623 Views, 3 Replies
I have created a custom component as a test, basically just a hollow cylinder, assigned a single insertion port & added it to my catalogue & spec with a threaded end type. When I run an iso it comes out skewed 5 degrees horizontal with an overall length of 500 (when in reality is is NOT skewed, and only 90 long).
Any thoughts?
3 REPLIES 3
Anyone? Anything??
jabowabo
You need to make sure the iso block that is being assigned is defined correctly.  I'd recommend copying a 'Cap' or 'BlindFlange' iso block  (or any other single port block) and do a 'Save-As' to create a new iso block for your component.  Be sure to map it correctly and it should work.
in reply to: jabowabo
Worked like a charm! Thanks so much for the solution & direction. You have saved me a great deal of frustration.
”Boost
