So Close!!!!
I have successfully added Catalog Properties, and populated these added properties to a spec via the “check for updates from catalog”. Unfortunately I am unable to create a Long Description Style that utilizes these user added properties.
Why would I want to do this?
To create a flexible time saving catalog system that quickly allows concatenation of user defined properties. For example Plant 3D uses an “End Type” of THDM, or PL, but a client would dictate that the end types would be PE, TBE, or TOExPOE, etc... The addition of these user defined properties into the Catalog would allow us to concatenate these properties to form a long description automatically
Attempted Workflow
See Screenshots below....
1
2
3
Hi, as far as i know, it will not be visible because you will need to add a property "as is" as what you had added in the spec editor. I had made custom properties in the catalog also and those worked great. I am using 2014 version for that matter. Thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Hi, i had misunderstand the last picture, i though it was the Setup interface but then as i reviewed, it is the Description interface. But still, try what i recommended, I'll test this later so i can help you out. thanks
Best Regards,
Pat Andres
GHD Manila
Thanks for the response Pat,
To be clear the last screenshot is from the "Edit long description styles..." dialog box, found in the Spec Editor. I'm am unclear on what you have recommended, please let me know how your testing goes. I tested again using the following steps.
Doug Webb
I've not seen this working. It's been reported as a bug, and a fix has been requested. As far as I can tell, the program loads the properties from a spec schema in the installation directory, not the current spec or specs.
I saw this reply shortly after you posted Dave Wolfe, and meant to respond, oops. Anyway, thanks for the knowledgable insight. I will keep my fingers crossed that this gets addressed soon.
This is still an issue. I get that I can go back and add properties in the catalogue, but if there's an option to add custom properties in the spec editor, then they should appear in the long description dialogue.
