AutoCAD Plant 3D Forum
Creating Sections not perpendicular to WCS
3 REPLIES 3
axeborn
639 Views, 3 Replies
Hi
I have a need to create drawings with sections from many different angles along a tunnel path. I.e not perpendicular to WCS.
Earlier I made a xref of the model with rotated insertion point. In this specific project this work flow should generate several xrefs. Is there any easier way of solving this problem?
I have noticed that when creating ortho view I am able to create UCS, but I cannot find any way to use this in viewport. Please see attached picture.
3 REPLIES 3
dgrant775
in reply to: axeborn
Same question for me too.
dgrant775
in reply to: dgrant775
Though you lose all P3D functionality, the work around is to export to ACAD and use the Generate Section commands.  Generate Sections may work with P3D objects but I haven't tried.
Hi Michael,
I'm sorry to say that there is no more elegant way to do it in 2013 but in the upcoming 2014 you can add jogs and use isometric or user-defined views when you want to create an ortho drawing. This should solve your need.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
”Boost
