We're running a project currently and few person doing different jobs.
When the plant model is opened in different computer and trying to generate ISOGEN
from there, an error message pops up:
Error 48: Unknown error in PISOGEN.
It seems ISOGEN can only be done in the computer which creates the Plant model.
Any idea why this happens?
Amalynn,
It sounds like this is a path issue. This is the message that Isogen gives when it can't find the path to the project. The project might have a hard coded path that the second computer doesn't have access to.
Dear Peter,
Thanks for your reply.
How can i resolve the issue of the hard coded path??
HI there,
I also have the same problem here. I tried to change the isogen location path, i stil have the same error coming out? Any step that i miss? Can you tell me the procedure to change the location path?
You might have to find the copy of ISOGEN.FLS in your project and edit it in notepad if the path to one of the files is wrong.
Hi Peter,
Thanks for your suggestion.
We have got the solution something similar to yours.
