Dear All,
I tried to made one Vessel with the shape in the attached file but the result not like what i want there are any one can help and how i can delete the some of the nozzle
Ahmed Helal
Solved by Dan.Scales. Go to Solution.
Why you don't try to do with revolve tool and convert to equipment later, from your 2D drawing?
you can do body and nozzels with that tool (revolve) and legs with structure tool.
After make a block with all items and convert it to equipment.
I think is the best way to do exactly equimment as you looking for.
I Agree With you, but in this cae why in Plant 3D product We have Equipments Tools For Use or non Use?
Ahmed Helal
To delete a nozzle you need to select the Nozzle with Ctrl + Left Click and then hit the delete button on the keyboard.
The question around the shape of the vessel is I believe addressed in you other post.
Dan
Thanks Dan,
I posted again this issue before I realize you already replied just I added how can I re numbering the nozzle ?
Ahmed Helal
