AutoCAD Plant 3D General DIscussion
Ahmed1081975
Message 1 of 6 (304 Views)
Creating Equipment (Vessel)
304 Views, 5 Replies
01-17-2013 11:30 AM
Dear Autodesk team Supports
I have issues for creating the equipment (Vessel) I tried to made one vessel by  Plant 3D I faced problem to get the shape what I want, I did by CADWORX Equipment and I attach the both did by CADWORX & PLANT 3D  did I missed something in the plant 3D??
Ahmed Helal
Try setting to value for dimension SF for the 2:1 Torispheric Head to 500 rather than 50.
In the image below, SF=50 is on the left and SF=500 is on the right:
I hope this helps.
Dan
Product Support
Dan.Scales
Message 2 of 6 (253 Views)
Re: Creating Equipment (Vessel)
01-21-2013 06:43 AM in reply to: Ahmed1081975
I hope this helps.
Dan
Dan Scales
Ahmed1081975
Message 3 of 6 (241 Views)
01-21-2013 12:10 PM in reply to: Dan.Scales
Thanks Dan For Your Reply, it's Working but i suggestion for this point butter if give one more dimension For
Torispheric head (H) for Height.
One more Issue for Creating Nozzle in the Equipment’s. I finalize the all nozzles in the equipment and get some new
Changes like (Re numbering the nozzle & Delete some of Nozzle how i can do that
Ahmed Helal
Product Support
Dan.Scales
Message 4 of 6 (238 Views)
01-22-2013 01:26 AM in reply to: Ahmed1081975
If you Ctrl+Left Click the nozzle you should see a pencil icon. Click the pencil and you can edit the nozzle tags:
Could you "accept as solution" if this has solved the issue for you?
Dan
Dan Scales
Ahmed1081975
Message 5 of 6 (227 Views)
01-22-2013 04:53 AM in reply to: Dan.Scales
Thanks Dan,  got it
Ahmed Helal
New Member
CouldflyLiu
Message 6 of 6 (171 Views)
01-26-2013 09:40 PM in reply to: Ahmed1081975
What is the SF meaning? Why does it like what you said, the dimension is 50mm rather than 500mm in real manufacture SF showed in the schema of PLD, Is there any more explaination?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
