AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Creating a Cross in Spec Editor
1 REPLY 1
sb
234 Views, 1 Reply
I am trying to create a 24" cross with bell ends. I do not have a block and cannot choose one from the AutoCAD directory. Any suggestions or has anyone created one of these already? Also, I do not know the correct geometry (ie.: engagement, matching pipe od (assume 25.8?), etc.)
1 REPLY 1
TomislavGolubovic
in reply to: sb
Do you have a catalog to pull the information from? Do you have a vendor who actually makes the item?
In the Specs and Catalog editor, when you add a new Component, under the Fittings Category, there is a Cross item in the Piping Component pulldown.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
”Boost
