Hi, i need help to create iso symbol for new part on spec editor and too select correct the iso symbols type and iso symbol skye on the spec editor, my isometric drawing have error by this, on the pictures can see a custom valve with actuator .
Solved by KenFauver. Go to Solution.
Solved by phwatso. Go to Solution.
If you haven't created yet a new SKEY for that valve, you can use the existing valves SKEY such as "VBFL" for Ball valve flanged type, "VBSC" for thread and so on. (SKEYS are added into the "IsoSkeyAcadBlockMap.xml" file. You can create autocad symbol and SKEY code just that, the block name must be mapped into the XML file correctly. Thanks and God bless.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I understand, but the only thing I am not clear is how save a new block iso symbol, sorry but you haven't a example of guide?
Take a look at the following document on the Autodesk Knowledge Network.
De-mystifying AutoCAD Plant 3D Isometrics a Configuration Reference
I have a problem with create a new symbol for shut-off valve and mixproof valve. I have read " De mystifying AutoCAD Plant 3D Isometrics" and try to create symbol follow the guide. it doesn't work in iso production. Please help me to create a symbol for mixproof and shut-off valve. thanks
this is type of valve i want to create a iso symbol.
in IsoSymbolStyles.dwg i create block "mixproof valve" with 4 ports
in IsoSkeyAcadBlockMap.xml, i insert "<SkeyMap SKEY = “IX??” AcadBlock=”mixproof valve”/>"
in content iso Symbol Definition i insert "TYPE=VALVE-MULTIWAY,SKEY=IXFL".
About the mixproof valves, a while ago i've been experimenting with splitting up the valve in, for example the one you posted, two 3-way valves and an actuator. Assining a custom ports to the coupling between the top and bottom half. In the end it did work, but the amount of time you have to spend making things to work is a killer, especially when you have to use many different type/sizes/etc. No Python here. 🙂
And for your other post (how to created a custom isosymbol) i would recommend to take a look on this site --> click (yeah, i know...spam..spam...spam.... but it's a nice site with many great tutorials, tips, etc.)
My client has many 3, 4, & 5 port block valves with 2, 3, & 4, valves/actuator on one assembly (bio-chem. eng). Sometime there are 4 port block valve with 3 actuators and two different end type (BWxTC) connections all in one assembly. I have a symbol from the vendor for the isometric but not sure how to create the xml file needed to read the symbol in the drawing.
