AutoCAD Plant 3D General DIscussion
Valued Mentor
18 Kudos
Post 1 of 5
Crashes
264 Views, 4 Replies
12-20-2012 04:45 PM
I have started writting down each time autocad crashes.
since Nov 15,2012 to now a total of 29 crashes.
what I have noticed is that 31% ( 9 ) crashes are just shutting down autocad.
save drawing, click the big red x - boom crash.
Any ideas on the nature of this type of crash? - obviously not impacting work.
but that is a large percentage.  next down from shutting down the computer is crashes when doing Orthos @ 14% ( 4 )
the rest are all singularities.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Valued Mentor
80 Kudos
Post 2 of 5
Re: Crashes
12-21-2012 05:38 AM in reply to: JohnHolder
- Which PC do you use?
- Which type of crash do you have (description, number, picture)?
-What did you do during the crash?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Valued Mentor
18 Kudos
Post 3 of 5
Re: Crashes
12-21-2012 09:59 AM in reply to: ybogdanov
Intel i7 2.8GHz
12gig ram
64 bit
duel ssd drives.
windows 7
Just an error report to send in.  nothing else.
shut down autocad - clicked the big X on the top right of the screen.
Master Yoda.
Product Support
35 Kudos
Post 4 of 5
Re: Crashes
12-27-2012 07:37 AM in reply to: JohnHolder
The first thing to check is the driver version of your graphics card:
Graphics Hardware
Also, if you do not have the service pack installed you should go ahead and do so:
Service Pack
If the crash still occurs try testing in diagnostic more to try and pinpoint any conflict:
Diagnostic Mode
If the crash does not occur in diagnostic mode then you can systematically enable the various services and/or startup programs to try and find what is causing the conflict.
Dan
Dan Scales
Valued Mentor
18 Kudos
Post 5 of 5
Re: Crashes
12-27-2012 09:22 AM in reply to: Dan.Scales
Downgraded the graphics card, must have updated it when I formatted the computer and reinstalled.
service pack does not work.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/AutoCAD-2013-Service-Pack-1-1-64-bit/td-p/.UNyDmG9QV8...
maybe the graphics card issue may have fixed that.. will test
Diag mode worked fine ^
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
