AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Coustem Valve
4 REPLIES 4
Ahmed1081975
397 Views, 4 Replies
Coustem Valve
Hi Autodesk Support Team,
I Did some 3D Model And Converted to Plant 3D By (PlantPartConvert) and I defined the Tow Connection (Flange Connection) but by mistake I chose the wrong location not in the center of the flange.  The question is there any way to change the location of connection without back to Cataloge and repeated all the steps for creating the model in the catalog??? For more clarification Rfer to Attached screen shot
Ahmed Helal
4 REPLIES 4
In the Catalog Editor, on the sizes tab, there is an option to replace the block.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
Ahmed1081975
in reply to: Ahmed1081975
I know This Option i thought there another way to do that in the autocad
Ahmed Helal
jason.drew
Use the PLANTPARTCONVERT command again on the block and you can edit the existing ports for the custom part.
Save the changes and then replace the model in Catalog Editor.
Jason Drew
Designated Support Specialist
”Boost
