Hi Autodesk Support Team,
I Did some 3D Model And Converted to Plant 3D By (PlantPartConvert) and I defined the Tow Connection (Flange Connection) but by mistake I chose the wrong location not in the center of the flange. The question is there any way to change the location of connection without back to Cataloge and repeated all the steps for creating the model in the catalog??? For more clarification Rfer to Attached screen shot
Ahmed Helal
In the Catalog Editor, on the sizes tab, there is an option to replace the block.
I know This Option i thought there another way to do that in the autocad
Ahmed Helal
Use the PLANTPARTCONVERT command again on the block and you can edit the existing ports for the custom part.
Save the changes and then replace the model in Catalog Editor.
