AutoCAD Plant 3D General DIscussion
Member
1 Kudo
Post 1 of 3
Correlation between port numbers in custom geometry.
173 Views, 2 Replies
05-21-2012 12:32 AM
Hi all.
Can anyone tell me if there is a correlation between port number and the order in which you add ports for custom geometries using PLANTPARTCONVERT command?
Does the first created port always get number 1? Or is it controlled somehow in spec editor?
Correct!
The port numbers in the spec editor are the port center points what you selected after the PLANTPARTCONVERT.
So the first selected point will be the port 1, the second will be the port 2 and etc...
Valued Mentor
30 Kudos
Post 2 of 3
Re: Correlation between port numbers in custom geometry.
05-21-2012 03:14 AM in reply to: Lars_Petersson
Correct!
Attila Vallyon
Member
1 Kudo
Post 3 of 3
05-21-2012 04:37 AM in reply to: attila_vallyon
Great!
Thanks Attila
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
