Hi all.
Can anyone tell me if there is a correlation between port number and the order in which you add ports for custom geometries using PLANTPARTCONVERT command?
Does the first created port always get number 1? Or is it controlled somehow in spec editor?
Solved by Attila.Vallyon. Go to Solution.
Correct!
The port numbers in the spec editor are the port center points what you selected after the PLANTPARTCONVERT.
So the first selected point will be the port 1, the second will be the port 2 and etc...
